Table of Contents
If you want to make your own version of the kit, read on.
The electronic components can all be purchased easily, but the wooden and plastic parts need to be made. I've used a laser cutter to cut out the wooden parts, and 3D printing for the plastic parts. So you will need access to a 3D printer and laster cutter.
I cut these with 4mm birch ply. Cut the red lines first, then the black lines.
Main board3D print this:
Switch block3D print these:
Wall 13D print this:
Magnet block3D print this:
Wire holderI recommend PiHut or Pimoroni or Kitronik for purchasing electronics for digital making. Here are some links for the electronics parts:
2x MicrobitsUse a microswitch with a very low operating force, such as this one with a 0.078N operating force:
SwitchThere are various buying options for Neopixels. You can buy long ones like this one and cut them to size:
NeopixelFor the LED display, there are various colours. Make sure you buy one with the Adafruit I2C backpack, which makes controlling it much easier:
LED displayYou'll also need some stranded wire. You don't need a lot, so you can buy a few individual spooks, but here is a link to a rainbow set!
Wire spool setI'm using a 10mm x 3mm rare earth magnet. I bought a batch from here, but you can probably find smaller quantities elsewhere:
MagnetI've used a 16mm steel ball bearing from
Ball and roller storeThere's a bit of wiring to do:
LED | Microbit Connector | Recommended wire colour |
VCC | 3V | Red |
GND | 0V | Black |
SDA | 20 | Orange |
SCL | 19 | Yellow |
Neopixel | Microbit Connector | Recommended wire colour |
+5V | 3V | Red |
GND | 0V | Black |
Din | 12 | Blue |
The microswitches have 3 terminals. Connect the terminal at the pivot end to the appropriate coloured wire and the middle terminal to a red wire.
Then on the microbit connector connect receiving wires as follows:
Switch | Microbit Connector | Recommended wire colour |
Green | 13 | Green |
Purple | 14 | Purple |
White | 15 | White |
All | 3V | Red |
Feel free to email me
Table of Contents
